Grue camion Palfinger RC4WD 1/10 - 1/14
Message  Corleone le Mer 29 Mar - 0:21
Il est indiquer 1/14 mais trop gros pour le camion Tamiya.
Ce serais l'idéal pour un camion 1/10.
1/14 Truck Mounted Hydraulic Crane
Your Price:$1,399.99
Lien RC4wd
Spécifications:
   CNC Machined
   Black, Silver and Red Anodized Finishes
   Aluminum Alloy Construction
   Operating Voltage: 11.1-12.4V
   40A Brushless ESC
   Maximum Lifting Force:
       3KG / 6.6lb Maximum for the Longest Arm
       3.8KG / 8.4lb Maximum After Folding the 6th Section of the Arm
       4.8KG / 10.6lb Maximum After Folding the 5th Section of the Arm
       6KG / 13.2lb Maximum After Folding the 4th Section of the Arm
   Height after Folding: 11.8in / 300mm
   Width of Front Feet: 7.5in / 190mm (Folded) 29.5in / 750mm (Extended)
   Width of Rear Feet: 7.5in / 190mm (Folded) 16.3in / 415mm (Extended)
   Maximum Lifting Radius: 35.4in / 900mm
   Maximum Lifting Height: 742.91in / 1090mm
   Hydraulic Pump: Power Flow 0.8L / MIN, Rate Pressure 2.5MPA
   Total Weight: 176.4oz / 5000g (Including Packing Material)
Re: Grue camion Palfinger RC4WD 1/10 - 1/14
Message  Bourineur le Dim 16 Avr - 18:00
superbe Twisted Evil
ça irait pile poil sur mon 8x8 Twisted Evil
mais va falloir économiser un peu Laughing
Bourineur
